KMC 3232E No black printing or copying.
  • yormets
    • May 2009
    • 336
    [CQ] KMC 3232E No black printing or copying.
    This box has only 75K. It said K toner low change soon. Customer installed new OEM toner, still said same message. Two days later, all black printing stopped. It warms up with no errors. B/W mode copies blank, color modes print in three colors only, no black. What happened? A clutch? Drums are supposed to be good for about 300K. I'm just shocked it doesn't error out when doing imaging warm up. Anyone seen this before?
    Roy
  • JustManuals
    • Jan 2006
    • 9838
    Re: KMC 3232E No black printing or copying.
    Paul@justmanuals.com
    • Geo
      • 662
      Depending on age of the K developer unit the rear seal may be damaged.This causes DV to leak out and chew up the gears. I have only seen this with the K dv unit,wondering if the heat from the fuser affects it.
      • yormets
        • May 2009
        • 336
        I've never worked on one of these. How do the units come out? A few screws I guess. They must come out the front.
        • Geo
          • 662
          I would highly recommend you get the service manual.However
          1 Remove the Fuser unit.
          2 Remove Transfer belt unit (BE VERY CAREFUL)
          3 Remove image formation unit (.(the assembly that holds the toner) their is a connector on the right side behind a cover plate.One of the screws is accessed with the toner holder in the up position
          4 Remove pin and connector holding dv unit
          If you do not have experience with color or kyocera line, I would get the service manual .....These can be a PITA.
          Have fun
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            check the white coupler for the toner cartridge, is it stiff or free spinning?
            free spinning means the gearing broken inside.
            Idling colour developers are not healthy developers.
              • 23006
              Have fun
              Like Geo says. Get the manual, and definitely read the disassembly/reassembly portion. In a sense you are lucky. If it was KM-C4035E it would have chewed up the black developing drive clutch also. The slower models don't have that clutch, just a motor.
              In addition, you'll need to do a full color calibration. Again, see the manual. It's all there. =^..^=
              • kyocera10
                • Sep 2011
                • 13
                exactly! replace the k dev unit
