250ci not displaying correct toner remaining
  • daveyball
    • May 2009
    • 314
    Have a 250ci, which displayed 10% toner remaining, it then asked for toner, the user took it out shook it, and then it said 30% remaining, it occasionally does this and the users have to wait a couple of minutes for their prints. I have changed the RFID board. It;s on ly happening on Black.
    Cheers
    • 23009
    Re: 250ci not displaying correct toner remaining
    The only trouble I've had with RFID boards is actually unplugging them at the connector through the rear frame (not intentional). There have been some cartridges that came through with not-functional RFID tags, but the machines ran, they just displayed " ... non-OEM toner ... ", and didn't show the bar graph for toner amount.
    Could it be, that your customers are doing extraordinarily heavy fill, and that the toner density is sagging enough to trip the "Toner Add" condition? =^..^=
    • daveyball
      • May 2009
      • 314
      They are just printing off average text coverage, nothing out of the ordinary. Is ther a way to stop it "checking" as often?
        • 23009
        Not that I'm aware of. It seems like something you can only make worse with fiddling. =^..^=
          • 23009
          If your customer is cooperative, perhaps you can have them run a developer refresh when these toner indications appear. If there is toner remaining, it will recover. If there isn't any toner to add, nothing lost. Toner Add stays.
          The only negative, is the 6 minutes that it takes to run the developer refresh. If you present it properly, the enduser can feel included, and be the special keyop. Who knows? Maybe they'll love you for it. =^..^=
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Have had many that the customer removes empty toner and reinstalls the toner and gets 70% full reading. Have had a customer complain that print job pauses to add toner every couple of pages only to find that yellow was empty, replaced toner and working perfect now. Something is wrong on these boxes...they are almost as bad as Ricoh color...LOL
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • knobby
              • Oct 2008
              • 75
              its normally a knackered dev unit
              • aabarnes1
                • Mar 2009
                • 620
                Toner remaing display is not an exact sience on any machine! However on the 250 you can set the calibration cyle to 'long' and follow all the tweaks associated with firmware upgrades, particularly to V10 and 11.
                Grant me the serenity to accept the things I cannot change.
