Kyocera 3050i fax confrim reports
  • crown123
    • Aug 2011
    • 11
    [Misc] Kyocera 3050i fax confrim reports
    having trouble finding fax confirmation reports... any ideas? thnx in advance.
    " O.K lady the washing machine is fixed... now stop putting paper in it -_- " - crown
    • 23009
    Re: Kyocera 3050i fax confrim reports
    From the Status button > Device tab you can print the current list. If you just want to look go to Status button > Log tab > Fax > then scroll through the list.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1890
      To turn them on for every sent fax Reports>result reports>fax Something pretty close to this. It's off the top of my head, so you can't expect much.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 23009
        System Menu > Print Reports > Result Reports ... I think. Closer, anyhow.
        And you've got a rep to live up to mister. =^..^=
        • tmaged
          • Oct 2008
          • 1890
          Man, I've succumbed to peer pressure. Here is the correct way
          Press the
          System Menu key.
          2
          Press [Report], and [Next] of Result Report Setting.
          Then press [Next] of
          Send Result Report and
          [Change] of
          FAX.
          3
          Press [Off] (not to print), [On] (to print), or [Error
          Only].
          If you selected [On] or [
          Error Only], you should then
          indicate whether the transmitted image is to be
          attached by selecting [Off] (do not print transmitted
          image) or [On] (print transmitted image).
          Hope that helps !
          -Tony
          www.dtios.com
          • crown123
            • Aug 2011
            • 11
            tyvm
