DIY Kyocera KM-4035 question
  • Tileguy
    • Sep 2011
    • 10
    I decided to fix my own copier (Kyocera KM-4035) and ordered in a maintenance kit. Several of the enclosures for parts specified a minimum software version required for installation.
    I entered maintenance mode and printed the report, which return the following values:
    019: ROM Version
    MAIN, MMI, LANGUAGE S1012C 2932LX 29336H
    LANGUAGE (Option), MAIN BOOT, MMI BOOT S2021B 29010A 29362D
    PRINTER, NWS, POWERSAVE 146.10
    DICTIONARY(2CX)
    KM-NET Viewer shows Engine Firmware to be S1012C-1=90
    The enclosure reference software versions as part numbers, such as MAIN: 2FG2931MY
    Can anyone tell me if firmware updates are required as I have no way to reference the part numbers to the versions?
    Versions required for new fuser:
    MAIN: 2FG2931MY
    MMI: 2FG2932HU
    Printer
    SOFTWARE ENGINE Ver.A008
    MAINTENANCE SOFTWARE: MS05
    Versions required for new various other parts:
    MAIN: 2FGS1015S
    If I do need an upgrade... can someone hook me up with the files?
    Thanks for your help in advance...
  • correo.tony
    • 72
    Re: DIY Kyocera KM-4035 question
    You need to be a official KYOCERA dealer for to acces to the private KYOCERA technical extranet and download the files !!
    Bye !!
    • Tileguy
      • Sep 2011
      • 10
      Thanks for the quick reply!
      Does that mean I need to update all the software, or do any of the versions I have meet the upgrade requirements?
      • luis8832
        • Dec 2008
        • 250
        you should upgrade to the latest version of firmware. I have the firmware you need. How do i get them to you.
        • Tileguy
          • Sep 2011
          • 10
          I sent you a pm with the info.
          • kyoceradude
            The Great Gazoo
            • Aug 2006
            • 442
            Another hero!!
            My mission here on Earth is to help all you Dum-Dums!
            • luis8832
              • Dec 2008
              • 250
              check ur email
                • 23010
                The threshold is at Main S2932 = version 134
                You're at Main S1012. That's a good reference which = version 139
                There have been a few versions above, the most current being S1015 = version 166
                But you are above the threshold, so you can install the maintenance kit without doing the firmware upgrade without doing any harm. If you decide to do the firmware, you will get a little better life from the fuser, among other things. See attached:
                My congratulations on actually reading the instructions. You would be surprised how few do.
                As a newbie, you may not know that it's bad form to beg for free stuff on your third post.
                • Tileguy
                  • Sep 2011
                  • 10
                  check ur email
                  Got em! Thanks!
                  • Tileguy
                    • Sep 2011
                    • 10
                    Well Mr. 5,000+ posts, I clearly made every possible attempt to avoid bad form by begging in my first post, not my third!
                    LOL
                    I did consult the Almighty Google at great length, but could not turn up anything on how to xref the p/n to version, and the files themselves are impossible to find. I figured straight up begging was my best bet.
                    Thanks so much for the info. I am a newbie to all this, but I figure I have tools and I'm not afraid to use them. Seemed to me $550 for the kit plus my time to figure it all out was better than the $1,600 the repair place wanted. I mean, the machine isn't even worth $1,600...
                    I'll be back to post when I break something... lol
                    • Tileguy
                      • Sep 2011
                      • 10
                      All went mostly well...
                      I found a spring and a broken piece of plastic while changing everything out. I'm hoping they were from the last guy, because I have no idea where they came from.
                      Problem: Tray 1 was always jamming prior to today. Paper was getting crunched up kind of thing. I replaced the rollers today, then did a test copy. It worked. I tried Tray 2 and it worked. Went back to Tray 1 and nothing. I got a Jam code #10 (didn't even try to pull paper). Powered off, checked the assembly again and made sure it was firmly seated. Tried again and got the same thing - it worked once. Wash, rinse, repeat, and on the third try, Tray 1 didn't work at all.
                      Jam 10 in the service manual says:
                      Feed switch 1 (FSW1) does not turn on within 841 ms of theupper paper feed clutch (PFCL-U) turning on; the clutch isthen successively turned off for 1 s and turned back on, butthe switch again fails to turn on within 841 ms
                      Any guidance on troubleshooting this?
                      • JustManuals
                        • Jan 2006
                        • 9838
                        Paul@justmanuals.com
                        • Tileguy
                          • Sep 2011
                          • 10
                          Never mind. It was a loose connector somewhere. I took it apart again and made sure everything was screwed down tight and it works fine now. Finicky machine...
                          Thanks again everyone.
                          Also... sorry Paul, but the service manual is free here:
                          KM-3035 4035 5035 Service Manual Rev1
                            • 23010
                            Congratulations on your successful PM. If you didn't, you'll need to reset some of the counters.
                            U251 for the PM counter
                            U903 for paper jam counter
                            U904 for service error count
                            U157 for developer drive time
                            U158 for developer count
                            U165 for fuser replacement
                            Also congratulations on reading and applying the contents of the manual. You would be surprised how many professionals come here to have someone else read the manual to them. =^..^=
                            • JR2ALTA
                              • Feb 2010
                              • 2033
                              I am surprised you fixed it, cassette jamming with a found spring and plastic thing.
                              A somewhat common problem is in the feed unit (which houses the feed tires), a small assembly is spring-tensioned, a plastic "pin thingy" holds it in place. It breaks and causes jamming.
