copies and prints stained taskalfa 250ci
  • marley
    • Sep 2010
    • 58
    dopo aver aggiornato il fw , le copie e le stampe appaiono con macchie
    vedi allegato
    dv bk da pulire??
    after updating the fw, copies and prints appear with stains see Annex dv bk to clean?
  • Metalvoc
    • Sep 2008
    • 155
    Re: copies and prints stained taskalfa 250ci
    you can check and clean for excess toner in and around the black dv unit. Then run U464 AC Calibration, DV and Drum Refresh modes, do your color registration and calibration.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
      • 23009
      http://www.freetranslation.com/
      • marley
        • Sep 2010
        • 58
        provero'
        grazie
        I'll try '
        thanks
        • Eric1968
          • 2458
          There is a new black development unit which solves this issue. First upgrade firmware to V12 and then replace the black development unit, and run U464. Here in Holland we can claim the old one and get a refund from Kyocera.
          • marley
            • Sep 2010
            • 58
            spero di risolvere il problema con la u464
            grazie
            I hope to solve the problem with the u464 thanks
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              We installed new style dev unit on a 400ci and a 552ci and both copiers make really odd noises when running (like a creaky door being opened).
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                • 23009
                I noticed that too, but it resolved the C7000 and C7101 codes. Imaging what it will be like with all four of them creaking. =^..^=
