C-2000
  • brancas
    • Jul 2009
    • 80
    C-2000
    Taskalfa 520i spitting out C-2000 error code. According to tech that was on site its a drive motor problem, paper stuck at exit section. Going to c problem myself. Had similar problem with Voyager E series solution was to change fuser motor. Going with fuser motor exit section fuser unit and latest firmware any other suggestions?
  • JustManuals
    • Jan 2006
    • 9838
    Re: C-2000
    Paul@justmanuals.com
      • 23009
      Re: C-2000
      I haven't experienced any exit drive drive problems, and I've got FalconIII machines over 1.5M
      What print count? Have you done any disassembly to look for sticky bushings, shifting rubber rollers, or warped plastic guides?
      That's my guess anyway. Let us know what you find. =^..^=
      • Metalvoc
        • Sep 2008
        • 155
        Re: C-2000
        Like he said.
        I have had 2000 codes on the Falcon. It was a problem with the drum unit. You could take the drum unit out and make sure everything is turning smoothly.
        I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
