Getting an unusually high amount of this jam code. I haven't gotten it to happen myself but the teachers who use this machine says it happens when they make around 50 copies of a packet they are wanting to staple. Has anyone else come across this issue?
TA 5500i j6310
Re: TA 5500i j6310
Could be paper curl. I had a lot of problems with that on the later Falcon finishers. Customer using crappy paper, and leave it sit out for a week or two before using it. Then when it's duplexed and finished, I have seen the paper curl up completely as it is coming out of that finisher intermediate tray.
How many jams has the machine recorded there? Try running a bunch of duplex packets to the main finisher tray, and cheat the front cover switch so you can watch the paper as it leaves the intermediate tray. That might give you a better idea of what is happening.I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain -
Re: TA 5500i j6310
But back to the DF-790: I've got two out in the world and they're working flawlessly, knock on wood. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: TA 5500i j6310
I lowered the fusert temp by a few degrees to lessen paper curl. I mean it is a public school so we know for a fact they do not use good quality paper. Gonna give it about a week with the lower temp and then check to see if it has improved."In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
Re: TA 5500i j6310
It's not that schools necessarily use crappy paper. However, every school I've been in has one of those shelves in the copy room with a hundred different colors of paper stacked up, opened. Eventually, someone decides to put that crap in the copier.
But I digress. I don't know that I would necessarily mess with the fuser temp to adjust your curl. Don't these new finishers have decurlers in them? I haven't had to worry about curl on any of them yet, so I can honestly say I don't know. If there is a curl adjustment in these finishers, I would adjust that, rather than possibly creating new problems with the fuser. Its a school, so again you can bet that sooner or later a teacher is going to walk in there with a piece of cardboard, run it through, and wonder why, "the ink doesn't dry"I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark TwainComment
