km 3035
  • kozanecki
    • Jan 2011
    • 12
    [Error Code] km 3035
    service code c 0240 printer board any suggestions?
    any help to ipkozanecki@gmail.com
  • Metalvoc
    • Sep 2008
    • 155
    Re: km 3035
    Try taking the print board out, take the memory and dimm off the board, and clean the contacts with an eraser. If the board is really dusty, clean out all the connections with canned air, or the like. Make sure the connector on the back of the print controller is seating fully with the main board. Re-flash the firmware for the print controller. If the firmware fails to load, you may have a bad controller. Though if it fails the first time, I would try re-formatting the CF card and trying again. I have had firmware fail, but work fine after a re-format.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • kkendric
      • 301
      Re: km 3035
      The F-DIMM can be the problem if the information it contains has become corrupt. There is also a heat pad under the IC with the heatsink. Often the silicone it contains seeps through the board and causes problems with the IC's. The F-DIMM can be ordered from KMA and should cost between $60 and 80.
        • 23009
        Re: km 3035
        All good points but one. I don't use canned air around electrical components anymore, because I've seen inadvertent damage by freezing. I've started using the Giottos Air Rocket. Rocket-air
        I've been using it for the last year and it works great, with no risk of freezing components.
        Personally I think it's going to come down to the print controller, but these are great steps leading you in the right direction. =^..^=
        • Metalvoc
          • Sep 2008
          • 155
          Re: km 3035
          Neat! I'm gonna take a look at that when I get back to the office.I don't carry canned air myself. Like I tell my customers, don't blow dust out of you electronics unless you know where its going. I find a brush, a cloth & a little breath works as well.
