C3C50 on a KM-C3130
  • Metalvoc
    • Sep 2008
    • 155
    [Error Code] C3C50 on a KM-C3130
    I have a customer that is getting this code now nearly daily. It is not in the manual, but I thought I had heard in the past that this was the "counterfeit" code. Though I may be thinking of a different error. The code comes back almost every morning, it gets reset, and the machine runs fine all day. I have replaced the main board already. Is anyone familiar with this one?
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • 23010
    Re: C3C50 on a KM-C3130
    Isn't this a Monica rebadge? Sorry, I haven't had to work on those. Well, not that sorry ... =^..^=
    • B0265
      • Jan 2007
      • 718
      http://www.copytechnet.com/forums/ko...rror-3c50.html
      • Metalvoc
        • Sep 2008
        • 155
        Thanks guys! guess I should have looked a little harder
        • techrm
          • 12
          You're right,it is a countfeit code.upgrade firmware and if that doesn't fix it,there is a board under the glass that has couple of ribbon cables and 3 or 4 other connectors underneath a metal plate i forget what it is called.
