DP-670B Weird image when sending document
  • jaslex
    [Misc] DP-670B Weird image when sending document
    Hello All....
    Currently trying to troubleshoot a copy quality issue when scanning thru the DP, the top part of the image (about 3inches comes out wavy). It was initially jamming, I changed the worn rollers but still cannot figure it out. It`s a fairly new machine (not that it means anything) so I`m taking out a possible bad switch issue. Could there be an obstruction that I can`t find? I know the users are pretty rough w/it...can it be a tweak somewhere with the alignment of the DP? If i give it a little twist, it works temporarily, then once I lift up the feeder, it resorts back to that little wave on the top. Any suggestions would be greatly appreciated, thank u!!
    • 23008
    Re: DP-670B Weird image when sending document
    Can you attach a scan? Is the DF height adjusted correctly? =^..^=
    • ES-OGT
      • Aug 2011
      • 129
      I had this happen before. Make sure the screws that hold the DP to the copier are secure. If the screws aren't secure the DP will float slightly enough to give you the wavy image problem.
