I'm getting an AO-610 error code, does anyone know what it means, it's not in the service manual , I know AO is a communication issue. CO610 is a dimm problem, but has anyone come across this before.
taskalpha 180 error AO-180
Re: taskalpha 180 error AO-180
C0180 is a Serial number mismatch. Have you been swapping around PWB's without switching EEPROM chips? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
I don't have an A0610, but I've got a C0610:
Bitmap DIMM Problem. There is a problem with the data or address bus of the bitmap DRAM. 1) Reseat DIMM on main/engine or main PWB, 2) Repl DIMM on main/engine or main PWB, 3) Repl main/engine PWB (180-220) or main PWB (181-221).
blackcat: Master Of The Obvious =^..^=Comment
