taskalpha 180 error AO-180
  • tecserve
    • Sep 2011
    • 7
    I'm getting an AO-610 error code, does anyone know what it means, it's not in the service manual , I know AO is a communication issue. CO610 is a dimm problem, but has anyone come across this before.
    • 23008
    Re: taskalpha 180 error AO-180
    C0180 is a Serial number mismatch. Have you been swapping around PWB's without switching EEPROM chips? =^..^=
    • tecserve
      • Sep 2011
      • 7
      sorry my heading was the wrong code, I havent done anything yet with machine (i swear) the error code is AO-610 on a taskalpha 180
        • 23008
        I don't have an A0610, but I've got a C0610:
        Bitmap DIMM Problem. There is a problem with the data or address bus of the bitmap DRAM. 1) Reseat DIMM on main/engine or main PWB, 2) Repl DIMM on main/engine or main PWB, 3) Repl main/engine PWB (180-220) or main PWB (181-221).
        • tecserve
          • Sep 2011
          • 7
          so far I've been in touch with UK tech support and they don't know, I'm waiting on word from Japan.
