KM-3060 CF423
  • MFPTech
    • 486
    KM-3060 CF423
    KM-3060 CF423 error even after replacing the Fax kit. The error occurs only when receiving faxes. No problem transmitting. Any ideas, please?
    Thanks in advance!
    • 23007
    Re: KM-3060 CF423
    Component: FaxJob. Category: FaxSys. The error came back when accessing (obtaining data, setting data) to below Entity related: job_ent(JobModel,JobInfo), config_ent, reservation, account(certificate), document_box.
    I don't know what it means either. But I'd start by removing the fax, and reloading the firmware. Then install the new fax, and reload firmware a second time. It's roundabout, but seems to work in these situations. =^..^=
    • kyocera.team
      • Aug 2010
      • 126
      Re: KM-3060 CF423
      Fax System the Error mean's : Wrong data or value detected when the following function is used. Or poor contact at fax card due to mus-installation or The IF error detects during system authentication from ACT_Account_Manager ...yes remove fax system then update firm ware as blackcat say's good luck ..
      • B0265
        • Jan 2007
        • 718
        Re: KM-3060 CF423
        I know it's and old post but how did you solve this?
        We have exactly the same problem in a KM-5050 (have also replaced the Fax Sys).
        • MFPTech
          • 486
          Re: KM-3060 CF423
          RAM
          • MFPTech
            • 486
            Re: KM-3060 CF423
            RAM
            Although the machine is 8 years old it was not the HDD or the Board. Replacing the RAM fixed the problem.
            Hope this helps.
