VoyagerE with some strange symptoms.
    • 23008
    By themselves each of these symptoms don't mean much, but together then start to point in a specific direction.
    The LCD display was on and functioning, but the backlight was off. I've seen these fluorescent backlights go out on Sharp products, and I would have ordered an LCD display, except ...
    ... that on that dark display the screen said "Left Cover Open." Then when I powered Off/On I got "C3100". So what does a dark display have in common with a door open indication and C3100?
    I thought that maybe a connector was loose on the power supply, but when I tracked down each symptom they lead to different connectors. Then I noticed on LC1SW (left cover switch) is supplied from "24v2" (24vdc second line?) on the power supply, as is the operation panel backlight, and the Scanner PWB. Sure enough, all the 24vdc sources on the power supply were dead (-0.2vdc).
    I'll be putting in the power supply tomorrow. I'm just hoping there isn't a direct short I haven't addressed. =^..^=
  • ES-OGT
    • Aug 2011
    • 129
    Re: VoyagerE with some strange symptoms.
    If the power supply doesn't work might I suggest scandisk (989 I think) and reformat (024) the HDD. Anytime we have odd situations that make no sense we've tried that and it works.
    If that doesn't work then you probably are looking at a short and good luck hunting.
      • 23008
      I'm closer. It will print, copy, and fax now.
      The NS30 is unresponsive. When I attempt a U504 NIC clear I get C0640. And it won't print a counter page.
      Do you suppose the HDD is toast, and took out the first power supply? I'll have more time later to try out the HDD. =^..^=
        • 23008
        This one just got put on the back burner. We sold them something new. When I get around to prepping the CS-4035E, I'll follow up. =^..^=
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          ewww...sounds really nasty.
          Could something be shorted? 00 ohms or 0 ohms?
          That's some awesome detail troubleshooting there Mr. Cat, I'd probably murmur "I'm not knowing" if this hits me lol.
          Idling colour developers are not healthy developers.
            • 23008
            Originally posted by jmaister
            ... Could something be shorted? 00 ohms or 0 ohms?
            No zero ohm loads. I checked.
            I was still concerned that I missed something, and glad that the new power supply didn't smoke.
            It's one of those situations where you are as careful as can be, but won't be sure until the power survives (or doesn't).
            I would have expected a cf14F error. I guess that the VoyagerE isn't as intelligent as the FalconIII. =^..^=
