7550ci dirty copies
  • monstott2010
    • Aug 2025
    7550ci dirty copies
    Getting black lines on copies/prints - cleaned charge rollers for temp fix, have replaced transfer belt and black drum(had small spots from drum), still waiting on a new fuser, however no physical indication that fuser related to lines but the belt is starting to blister on edges so ordered new fuser to replace.... any suggestions?
    • 23009
    Re: 7550ci dirty copies
    You say that you cleaned the primary charge rollers, and the image quality improved.
    Have you considered replacing the primary charge rollers, and maybe performing a color calibration? It sure seems logical. =^..^=
    • Metalvoc
      • Sep 2008
      • 155
      Are you up on your firmware? V.3 update included some measure to prevent "toner dusting". It made some change to the main charge values.
      I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
