SCAN TO E MAIL
  • grandpapro50
    • Sep 2011
    • 18
    [Misc] SCAN TO E MAIL
    I have never done scan to e mail before---i know you have to get certain info from the client to make it work, such as host name, port #, etc
    if the client doesnt know this info is there a place i can get it?????
    And can someone give me a- step by step- instruction on scanning to e mail--- kinda like scanning for dummies
    much appreciated
  • Kelvinator
    Re: SCAN TO E MAIL
    What model are you trying to set up?
    • grandpapro50
      • Sep 2011
      • 18
      Re: SCAN TO E MAIL
      ITS A CS 3500i
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1907
        Re: SCAN TO E MAIL
        Do a search. I've explained it extensively on here.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • grandpapro50
          • Sep 2011
          • 18
          Re: SCAN TO E MAIL
          Tony---did a search and could not find the step by step---- do you have a link???????
          • dickierock
            • 252
            Re: SCAN TO E MAIL
            Hi,
            first I would suggest when you first install the machine leave dhcp on.Then switch on the machine and it should pick up a lot of the information you need,ip address,dns etc. Then switch dhcp off so you have a static ip address for the machine.
            You need to get the smtp server address from the customer and go to the web browser of the machine and input that and other fields if required.Then add an address in the address book.Test.If the customer is using internal mail server like outlook then it should be straightforward enough.You will always come across different problems but this networking lark is an ongoing learning expierience and an installation can be a 2 minute "piece of pee" or 2 hour ordeal.Best of luck!
            • Eric1968
              • 2456
              Re: SCAN TO E MAIL
              Maybe this sounds a bit rude, but all these things can be found in the documentation that is supplied with the machine.
              • tmaged
                • Oct 2008
                • 1907
                Re: SCAN TO E MAIL
                http://www.copytechnet.com/forums/ky...tml#post115185
                http://www.copytechnet.com/forums/to...html#post72329
                Hope that helps !
                -Tony
                www.dtios.com
                • TheOwl
                  • Nov 2008
                  • 1731
                  Re: SCAN TO E MAIL
                  Just check what account settings are in your clients email client such as Outlook or whatever. That will tell you everything you need to know.
                  • tmaged
                    • Oct 2008
                    • 1907
                    Re: SCAN TO E MAIL
                    Yep, but without DNS, you won't get anywhere.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    • TheOwl
                      • Nov 2008
                      • 1731
                      Re: SCAN TO E MAIL
                      Most email should have a static IP address and if they don't, then it isn't hard to get a machine to use a router or a Google DNS server to relay DNS requests.
                      If the mail server is internal, use the internal DNS server. If it is external, then use 8.8.8.8 (Googles Public DNS Server) as a secondary DNS server setting on the machine.
                      Internal DNS can be found by going to the command prompt and typing in "ipconfig /all" (without the quotation marks) and that will give you everything that a computer uses which you can then use on the copier except for the IP address that the computer is using.
                      Better still is to use a DHCP reservation for the copier so that all that information is automatically gathered by the copier along with the same IP address everytime.
                      • TheOwl
                        • Nov 2008
                        • 1731
                        Re: SCAN TO E MAIL
                        Sorry, that first bit should have read "Most Email Servers"
