white lines
  • brancas
    • Jul 2009
    • 80
    white lines
    KM-C3232 with over 400,000 copies printing with white lines.Maintenance Kit was changed at 300,000 copies. Did drum developer refresh auto grey adjust no joy.Did a print out U89 colour belt saw white lines on black and cyan colours. Replaced black and cyan developer units swapped drum units changed transfer belt no joy. any suggestions?
  • blsquires
    • Nov 2008
    • 342
    Re: white lines
    two things ,first go to system menu ,user adjust ,laser scan cleaning.do this (just the cleaning bit )at least three times then check it .if no improvement clean or replace the charge roller (in the left hand door).
      • 23009
      Re: white lines
      Agreed. If the laser slit glasses are continuing to get contaminated with toner, either 1) the color developers are severely overtoned, or 2) you've got one or more cleaning units that is not transporting the waste toner away properly.
      In the first case 1) you can tell by checking U131 > Auto. Replace any developing units differing from the reference by 25 points or more.
      In the second case 2) check that the vertical guide unit B1 is closed properly, the green handles and springs and clips intact, and that the bevel gears are not jumping in the hopper assembly. Once you solve the cause, you may have to replace one or more drum units contaminated with toner rocks in the cleaning unit.
      In either case you'll have to perform a color calibration afterwards. =^..^=
      • rashid120
        • Jun 2010
        • 76
        Re: white lines
        [ATTACH=CONFIG]13269[/ATTACH]
        Please Clean the laser unit.remove totally from the machine and clean the mirrors inside the Black cover.Regards Rashid.....
