km-5050 cassette
  • dayosoof@yahoo.com
    • Aug 2010
    • 18
    km-5050 cassette
    I have a km-5050 I replaced d broken rack cursor in d cassettethat worked fine but later discovered a week later that when u close d cassette,it displays ( READY TO COPY) but immediately displays ( CASSETE NOT INSTALLED) again.....all connectors & cable in d cassette are intact,pls wat do I do next
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: km-5050 cassette
    Sounds like the lift motor, It could have taken out the engine board as well.
    The gene pool could use a little chlorine.
      • 23010
      Nothing new to add. Ditto. =^..^=
        • Aug 2010
        • 18
        Nah,I doubt its d lift motor because I tried a new cassette in & it worked fine,thanks
        • aodtech
          • 194
          With the cassette removed, push the the switch with the white flange. This tells the machine that the cassette is inserted and activates the lift motor. If a different cassette is working then this tells me that something in the current cassette isn't pushing in that switch. Match it up and check that part of the cassette, shim it if you have to. Also remove the switch and check to see if anything is cracked. All the connector does it tell the machine the paper size, which you can specify manually.
