TA-5500i
  • stg007
    • Dec 2011
    • 14
    [CQ] TA-5500i
    I have intermittent black copies, in print and copies with different media type. New drum unit and laser unit. New firmware 3.01 installed individually with compact flash.
  • kyocera.team
    • Aug 2010
    • 126
    Re: TA-5500i
    how about main charger or high voltage?
    • Eric1968
      • 2458
      Re: TA-5500i
      If you have black copies, you have a problem with drum charge. If the laser is the problem you will certainly get an error.
        • 23010
        Re: TA-5500i
        Firmware 3.01 sure claims to fix a lot of issues, but I agree with Erik. It's got to be primary charge related. =^..^=
        • stg007
          • Dec 2011
          • 14
          Re: TA-5500i
          With my new drum unit, the charge roller is new. In the past with other machine, no code was givin with quality problem concerning laser unit on KM-4530.
          I'll tried high voltage unit, but my problem is intermittent!
          If i fixed my problem, i'll give you my fix!
          Thank's
          • stg007
            • Dec 2011
            • 14
            Re: TA-5500i
            Finaly, it's fixed.
            Between high votage PCB's and the plate who will touch the drum unit, a wire is attached and connected, but in the middle the wire is cut and reconnected with a tension spring. This spring wasn't sit properly on the bottom.
            Thank's
              • 23010
              Re: TA-5500i
              Congratulations on a tough one! Did you take a picture? I'm curious. =^..^=
              • stg007
                • Dec 2011
                • 14
                Re: TA-5500i
                No sorry, I can't imagine a stupid way to made machine, so many years with this manufacturer.
                No clamshell, where the machine have to open, i don't understand why they didn't put a complete wire to the connection.
                Thank's
