kyosera km 6030 machine suddenly switches itself off
  • jhon paulivan
    • Dec 2011
    • 18
    • 23009
    Re: kyosera km 6030 machine suddenly switches itself off
    Are there any error codes or jam codes stored? Is this heresay, or have you actually seen it do it, yourself?
    Was there some other function in progress when it shut down? Is there a timer set? =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Metalvoc
        • Sep 2008
        • 155
        These things draw a lot of juice. If it is not a true 20amp circuit, it could cause problems. Also, I have seen people plugging things into the same circuit as a device like this, and when they are both running, it can cause problems. I don't know that I've seen one of these devices turn off because of this, but I had a customer with their computer on the same circuit. Every time the 6030 was turned on, or came out of power save, it shut the computer off. If you have a tester, it might help to test the outlet you have this plugged into, and make sure it is the only device on that circuit.
        I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
        • aabarnes1
          • Mar 2009
          • 620
          I agree to a degree, put a surge protector on the circuit, disconnect adf and run. When exactly is this switching off happening?
          Grant me the serenity to accept the things I cannot change.
          • logrady2331
            • Feb 2011
            • 301
            Replace the main switch itself, sometime the relay is goffy but that can be cleaned.
            • RWAFA
              • Aug 2011
              • 68
              hi,when say the machine switches off,do u mean to say it switches off on the display or it triggers off the main switch?
