TaskAlfa 250 ci DEAD ...... :-)
  • spiderman76
    • Mar 2009
    • 59
    • 23009
    Re: TaskAlfa 250 ci DEAD ...... :-)
    I have a problem with a taskAlfa 250ci. The machine displays waste toner full, even when bottle is empty. I updated the firmware to version 12. The problem was not resolved.
    The simplest solution is the best place to start. I would start by cleaning the waste toner sensor (WTS). If that doesn't help I would track the harness back to connector YC2 pin 4, and YC9 pin 7 on the sub-front PWB. If that doesn't help I would track the harness back to YC19 pin 14 on the engine PWB.
    You can test the output from WTS in simulation U155 > Overflow.
    I hope that this translates understandably.
    Translation courtesy of: Free Translation and Professional Translation Services from SDL =^..^=
    • spiderman76
      • Mar 2009
      • 59
      I changed this assembly ( see PDF attachment ... )
        • 23009
        ... The simplest solution is the best place to start. I would start by cleaning the waste toner sensor (WTS). If that doesn't help I would track the harness back to connector YC2 pin 4, and YC9 pin 7 on the sub-front PWB. If that doesn't help I would track the harness back to YC19 pin 14 on the engine PWB.
        Spero che questo traduca naturalmente.
        OK. What's next?
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • spiderman76
            • Mar 2009
            • 59
            YEAHHHHHHHHHHH!!!!
            The problem is .................. PARTS PWB FRONT SUB ASSY !!!!!
            Thank a lot CATTTTTTT !!!!!!!!
              • 23009
              I'm glad to help.
              Sono contento per aiutare.
