FS-2626 Close rear cover1
  • subaro
    • Oct 2010
    • 1274
    kyocera fs-2626 gives error message closer rear cover1. i removed hv pcb and can see the switch. when i press the switch the rear cover actuator, i can see that it is not depressing the switch, but just sitting on top of it. there is some mechanism that is causing the actuator not to press down on the switch. the switch itself is good as i can get continuity when check with the meter. I have started to disassemble the unit to see that actuator and how it works but service manual does not show that deep. any suggestions
  • subaro
    • Oct 2010
    • 1274
    Re: FS-2626 Close rear cover1
    I have finished the reparis to this machine today. to get to the parts and mechanism, had to do some detective work to see where screws and tabs are. This job test your patience and nerves, but after the repair you can do it with confidence. a lot of the steps to get to the actuator is not in the service manual and you just have to figure out things.the toner lock mechanism tooth and the right cover hinge was not in sync. The top cover has to be opened fully for the toner to be inserted correctly. if not the customer trying to force the toner in will cause the toner lock gears to break the teeths on the toner lock mechanism [ see photos ]. [This one was not broken, but out of alingment, so to align the mechanism and reinstall it is a task, if never done before. you may have to do some trial and error before you see how the aparatus work].so when the mechanism is out of position the rear door actuator in this case when pushed is not pushed against the projection on the toner lock mechanism so that the actuator is not forced down as it is supposed to. The switch is not in the photos as i forgot to install it when taking the pic. Anyway, hope no one runs into this as this will set you back a day or two. Also make sure you have the right top cover hinge at hand if you are going to do this job and this is not for the field, at least for the first time.Hope this may be help to anyone who runs into this.
      • 22999
      Sounds genuinely unpleasant. So the key here is to be sure that the top half/scanner is fully open when changing toner?
      Thanks for sharing. =^..^=
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1869
        They've changed the rear door latch, make sure yours isn't broken. We've also got one torn apart waiting for parts. Pain in the butt to tear down that far. I've also fixed a registration sensor that was popped out of place. This isn't in the manual either, but three screws & two tabs released & you can get it off.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • subaro
          • Oct 2010
          • 1274
          thanks temaged for your reply. just intrested to know the shortcut for the three screws and tabs, as i was thinking, if ever i have to do this again i will have to find a eaiser method. point me as to the location of those three screws as it will sure save a lot,lot of time. I am referring to the right side toner support plastic with the rail and gears..
          thanks
          • tmaged
            • Oct 2008
            • 1869
            Subaro, this is actually for the registration area where the sensor is mounted. I've had to pull two of these apart when the sensor gets popped out of place.
            Hope that helps !
            -Tony
            www.dtios.com
            • subaro
              • Oct 2010
              • 1274
              Thanks again tmaged, yeh, i had to remove that also in the teardown. just a note on that though, when reinstalling it, the spring it looks like a ground spring and when assembling the reg unit to the frame, there is a small hole for that spring to fit into to be grounded. just thought i mentioned that to anyone reinstalling as it may be easy to bypass that.
              The top cover, toner lock gears aparatus and the rear door actuator and switch, all work in tandem and if the toner is not installed correctly, and is forced in, there will be problems and big ones. The good thing about this repair is when everthing was put back together, the registration and print quality was bang on.
              thanks again for the pics and all
              • imaan
                • Sep 2016
                • 11
                Thanks for this post. I registered here just to see your photos. well I have got same machine, UTAX CDC 5626L which is same as Kyocera 2126.
                I have same problem, machine keeps saying close rear cover. this happened when I removed the black toner since it was out of ink. I put the toner genteelly back to the machine but still Im seeing same error.
                so should I remove the toner and adjust the gears then I install it, so that this error goes away or I have to disassemble the machine?
                any help is highly appreciated
                btw if you can send me a picture of actuator, that's a big help, in case I need to open the machine.
                regards
                • imaan
                  • Sep 2016
                  • 11
                  regards
                  YAAY.. finally I managed to solve the issue. by the help of this post,
                  there is a lock to secure the toners in their place. if you don't close that lock after replacing the toners, the rear cover actuator will not work properly so the machine will show you : "close rear cover 1"
                  inside the machine on top of black toner, there is that lock, when you put the toners in their place, press it down , then close the top cover.
                  when done, open the rear cover once and close it, you'll see that machine will be ok and the error will dissappear .
                  cheers
                    • 22999
                    Congratulations on your success. =^..^=
                    • skifab
                      We hade the sam error message and found the problem with this switch not being pressed good enough. When pressed with a screwdriver it detected it as closed:
                      The solution was to cut a piece eraser and fit it under the under the plastic stick in the hole.
                      • tonerleak
                        • Mar 2012
                        • 67
                        My recommendation:
                        1- Buy a boat
                        2- Buy a length of sturdy chain
                        3- Wrap said chain around this POS printer
                        4- Throw printer overboard as your anchor
                        5- Crack open a cold beer as a reward for a job well done
                        * Spent too much time with theses units to say anything positive, either they work well or they are riddled with problems
                        • Tonerkiller
                          • Oct 2012
                          • 668
                          RUN
                          • JR2ALTA
                            • Feb 2010
                            • 2030
                            Closing the top lid of this POS controls: Toner agitation, toner add, developer agitation, transfer shutter, rear door close. It's the craziest design I've ever seen. And for all your troubles rebuilding it, the damn thing will drop toner on your prints anyway.
                            Once, I spend two days doing that damn bulletin and it still said "toner installed incorrectly" and it turned out to be one of the knobs on one of the cartridges itself was turned off-kilter. There was pure hatred in my eyes that day.
                            • whostheman
                              Hello guys,
                              Same problem: "close rear cover - 1" on my Kyocera ecosys M6026
                              I managed to fix this problem but let's say in a quick & dirty way. I open the right cover with force and removed the PCB to remove the sensor making this error.
                              In my case I had only a tooth jump in the mecanism (no tooth broken).
                              This was making the rack to not push enough downward on the sliding plastic piece pushed by the rear cover pin.
                              This tooth jump thus make the microswitch not to be fully pushed by the rear cover pin so I just removed the sensor and shortcut the wires.
                              Everything is working fine now. This mecanism is meant to sense if all the cartidge are well open when the top cover is closed but in my case one tooth jump was only affecting the microswitch.
                              Thanks for the information!
                              Bye bye
