KM-2560 Scan-to-email With Exchange 2010
  • trigon
    • Jul 2025
    Hello
    We have a KM-2560 currently running firmware 2H0_2F00.011.006 (2008.03.18)
    As we have upgraded our Exchange server to 2010 we now have a problem with Scan-To-Email. The sender account is required to use SSL on Exchange 2010 but I can't see any way to enable it on the KM-2560
    I know there is at least one later firmware revision to this copier, does anyone know if this enables accounts to use SSL?
    Alternatively, does anyone have a suitable workaround that doesn't involve lowering the authentication security on the Exchange server?
  • Mooseface2r
    • Jan 2011
    • 114
    Re: KM-2560 Scan-to-email With Exchange 2010
    There are alot of other threads reguarding this sort of problem with exchange 2010, try searching for something about adding a receive connector. normaly eliminates a need for a password and means it will only allow connections from the one ip.
    • trigon
      Thanks for the quick reply - I was just about to edit my post to say that I have setup a dedicated SMTP connector to get around the porblem, but ideally wanted to be able to get rid of this.
      Do you know if later firmwares do include secure athentication?
        • 23008
        Negative. =^..^=
