Kyocera
  • jose1020
    • 41
    Kyocera
    I have replaced drum unit and toner unit and copies come out with background Kyocera km 4050
    • 23010
    Re: Kyocera
    How about optics? Have you done any cleaning there? =^..^=
    • eurokris
      • 120
      Re: Kyocera
      post the sample print
      thanks
      • jose1020
        • 41
        Re: Kyocera
        No.I replaced drun unit, toner unit, transfer corona and charge corona.I replaced this parts the reason was some times the copies come out black
          • 23010
          Re: Kyocera
          Dirty scanner optics can do that, too. I usually try to organize my efforts from least expensive to most expensive.
          I seem to recall "background". When did it become "intermittent black copies"?
          You may have arcing between the contact on the back frame contact to the primary charge unit contact. =^..^=
          • jose1020
            • 41
            Re: Kyocera
            Can you tell me if that drum has any adjustment
            • jose1020
              • 41
              Re: Kyocera
              I don't have any right now but when it prints come out with background
                • 23010
                Re: Kyocera
                Nope. U081 is an exposure adjustment, but I wouldn't try using that for an intermittent problem. =^..^=
                • jose1020
                  • 41
                  Re: Kyocera
                  Can you please tell what is the drum refresh operation and how you do it
                    • 23010
                    Re: Kyocera
                    Drum refresh is intended for a drum that is cold or may be exposed to excessive humidity, for example installing a drum unit that is cold from sitting out in the car. I suspect that cold may not be a factor for you, but humidity may be. Place ledger (or A3 for you metric countries) paper in the MP Tray. Drum Refresh uses the abrasive properties of toner and paper rubbing against the drum to remove any moisture on the drum surface. This function is available from the System Menu, Adjustments, Drum Refresh.
                    But personally I don't think that this function will do anything for you. Moisture on the drum presents as light of blotchy light areas in the print. Did the problem change again? I hate these moving targets. =^..^=
                    • jose1020
                      • 41
                      Re: Kyocera
                      Let me explain again before I replaced the new units the machine copied with good quality the problem was sometimes the copies come out black I replaced with the new units and now the copies come out with back ground
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        Re: Kyocera
                        You may have an intermittant dev bias fault.
                        Replace the entire dev tank with a test unit.
                        • ES-OGT
                          • Aug 2011
                          • 129
                          Re: Kyocera
                          Did you put a 3050 drum in by accident?
                          There is a difference between the drum units for a 3050 and the 4050/5050's. If you go one way it still works but the image is off a bit and the other way I think gives you this problem.
                          Just a thought.
                          • finni72
                            • Jul 2010
                            • 25
                            Re: Kyocera
                            Hi!
                            I have had this problem on my Olivetti d-copia 500MF.
                            The problem was the charge unit.
                            There is an issue with the cleaning motor unit, so you don't manage to
                            intstall the charger right.
                            I think it is an lever that you just need push with an screwdriver to
                            install it right.
