falcon 2, fax
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    falcon 2, fax
    this is a tough one. Fax acc (J)
    It works in a test machine somehwere else, but in the client's place, it cant send nor recieve. No VOIP, and telco came around 3 times, change CO lines...still doesnt work.
    It was working all last year but suddenly cease functioning 2 weeks ago. Fax noise is present but no handshake happens.
    I've looked at a previous thread here, but...slower baudrate and disabling ecm didnt help.
    Anything else I need to look at?
    thx gents.
    Idling colour developers are not healthy developers.
  • blsquires
    • Nov 2008
    • 342
    Re: falcon 2, fax
    i have had the same problem and a 906 fixed it .hope this helps
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Re: falcon 2, fax
      I think 906 is not associated with signal attenuation and data loss.
      thx for the quick follow up.
      • ES-OGT
        • Aug 2011
        • 129
        Re: falcon 2, fax
        What 906 does do is re-enable any part of that fax that is disabled. I've never seen it work but it doesn't hurt to try.
        • blsquires
          • Nov 2008
          • 342
          Re: falcon 2, fax
          my thoughts exactly on the 906 if it was a totaly seperate item but it runs through or via the machine.if the facs board runs ok in another unit then its possibly the copier thats the problem so that may be why the 906 works
            • 23010
            Re: falcon 2, fax
            You might try re-seating the cables to the fax option. Be especially careful with the ribbon cables.
            I transferred a fax kit from one machine (where it worked), to another machine (in which it didn't). I had not been careful enough with the ribbon cable, and a couple of the conductors had peeled back.
            I got some truly weird symptoms.
            Can't access service mode. Can't download fax firmware. Can't access Fax Defaults in the System Menu (only the double beep). Can't access Fax Reports tab in the Fax screen (button grayed out). "Cover Open" indication when no covers are open. "Please Wait. Cannot be combined." when attempting to fax out. Ribbon cable from the fax control PWB to the main control PWB is damaged by removing the cable without releasing the clasp. Trim off the damaged end, or replace the ribbon cable (3CM27010).
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              Re: falcon 2, fax
              thx guys,
              906 was the first thing i tried.
              but its clearly not the machines now. after few loaners...none can send or recieve now.
              phew. I wonder what could really be the cause.
              • shep
                • Sep 2010
                • 108
                Re: falcon 2, fax
                i think that if you have tried more than one loaner and you know those machines worked in other locations it has to be the fax line. have you tried to put a dsl filter on the fax line.
