mita dc211 !!Damn jamming
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Jamming] mita dc211 !!Damn jamming
    hi to all
    i have Mita dc211 , there is a sensor indicates JAM but i cleaned all the sensors In the right section but In vain ,Is there who knows an idea about the sensor who did this jam
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • HaTePlOw WoRc
    Re: mita dc211 !!Damn jamming
    Did you try replacing the exit sensor if you can find one? The exit sensor tends to fail because the heat from the fuser section wears it out over time. Hope this helps
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      but the JAM Is on the right side!! not in the FIXING section
      DAMENE ABDEL AZIZ
      DJELFA
      • HaTePlOw WoRc
        Sorry I didnt read the part about the right side my mistake. I think we have an old one out back so ill try to take a look and jog my memory. Such an old machine its been a while.
        • ott
          • Mar 2011
          • 22
          It says you're a senior tech so I hate to suggest the obvious but did you clean the registration or timing sensor?
            • 23009
            OMG! Mita DC211? Where did you find it?
            The 211/2105/213RE/313Z/313ZD all use reed switches. So when the developer dumps, it collects on the magnet actuator of the registration switch. =^..^=
            • Geo
              • 662
              Blackcat...
              How in the world did you remember this??????
                • 23009
                This is why I've forgotten how to tie my shoes. My head is filled with totally useless crap.
                I spent an entire afternoon trying to fix a DC-213re that had a light area along the front of the page. After 3 hours I finally gave up on fixing it. So I put the black inner cover back on, removed the key, and closed the front door. To my surprise the problem instantly disappeared! The sun was shining through a basement window and right in through the gap around the toner cartridge. That black inner cover must have been designed just for that purpose. I sure felt like an idiot. =^..^=
                • Pinoy_Tech
                  • Feb 2010
                  • 47
                  Ohh, this model reminds me something about my younger age in Mita. We need to take a deep breath to take the drum unit off the machine. I almost forgotten the mechanical construction though I overhauled them a lot including the scanner clutches.
                  • copygal
                    • Feb 2012
                    • 23
                    thought for sure these were all gone by now, but I still remember them. i still have a dc-111 in use. i tried to give the customer a replacement machine and he wouldnt take it....Arrrggg! Didnt know if you have checked the single sheet bypass switch on this unit. I had one with a cheetoe on the bypass switch...in a daycare of course.
                    • Venom
                      Technical/IT Support
                      • Nov 2009
                      • 765
                      Funny story...another tech was working on one of those in the shop for faint copies. He strips insulation off the wire going to the transfer block and is holding a meter lead on wire...tells me to press print...I say Are You Sure...Ya press print...so I do and the platen starts moving and I see blue electricity arc an inch to his finger and knock him off the chair...damn near pissed myself laughing. A week later same tech is working on an electronic typewriter power supply...in those days we used pagers that vibrated...so we couldn't resist phoning his pager...just as he touch the board his pager vibrated and he damn near hit the ceiling he jumped so high...LMFAO
                      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                      • alpha-omega tech
                        • 80
                        Carry brasso and a cotton pad to polish the drum and you will get more copies from your drum. Oh, the bad old days. I remember them well.
                        • ignacio.cortez
                          • Jul 2010
                          • 176
                          I've had copiers with items on the Bypass, and they were Lawyers or Accountants (food items) Most of my schools or preschools were clean :-)
