Kyocera Mita FS-1018MFP Firmware update
  • livewire
    • Sep 2011
    • 608
    Hello everybody,
    we have Kyocera Mita FS-1018MFP with System firmware: 2DD_2000.001.044 and
    Engine firmware: 2DD_1000.001.031
    Currently we use "KMnet Viewer 5.2.1928" to upgrade firmware.
    In this case we have Machine firmware: S2DD_2000.002.006 and Printing system firmware: S2DD_2000.E03.003
    My question is whats files must sеlect from firmware upgrade wizzard window?
    See attachment files.
    Thank you.
  • Eric1968
    • 2458
    Re: Kyocera Mita FS-1018MFP Firmware update
    You'll have to use a compact flash card to upgrade firmware on this model.
    • livewire
      • Sep 2011
      • 608
      Hi Eric1968,
      thank you for quick respond. I know for this procedure from Service Manual and i think it is possible to make with KNnet viewer.
      • Eric1968
        • 2458
        Never tried it with KMNetviewer, and I don't think it's possible, but the files/folders you need are :
        Folders
        NANDinstall: NAND side Install command group
        NORinstall: NOR side Install command group
        Files
        Initrd: Initialization processing file
        PPCBoot: Boot program
        RootDiskImage.jffs2: Controller program
        SetupDiskImage.jffs2: Controller program setting file
        VERDEF: Configuration file
        zImage.kmmfp: Kernel program
        • Eric1968
          • 2458
          I find it always a bit tricky when updating the firmware using a network connection. If the connection for one moment fails you could be in real trouble.
          • livewire
            • Sep 2011
            • 608
            I have these files/folders.
            But i don't know which of the files should be select.
            In KMnet viewer firmware update window have place for only one file.
            • Eric1968
              • 2458
              I think that's the reason why you can't update using KMNetviewer. I would buy a CF-Card with a CF-reader/writer.
              • livewire
                • Sep 2011
                • 608
                Today will order Compact flash card and execute procedure from Service manual.
                Thank you.
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  Caution...too big of a CF card won't work
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                  • livewire
                    • Sep 2011
                    • 608
                    We successfully upgrade firmware.
                    Thank you guys.
                    • XIXO123
                      • Jan 2022
                      • 2
                      Hi. Where I can find the Firmware files? The only site with files and manual is Centro de soporte | Soporte | Kyocera and there is not Firmware files, only .BIN files
                      • copier tech
                        • 8144
                        Happy to help.
                        Printer & Copier Firmware - www.printerfirmware.co.uk
                        • XIXO123
                          • Jan 2022
                          • 2
                          SOLVED. The firmware can be downloaded from https://www.elektroda.pl/rtvforum/to....html#19175098
                          or in the canal Telegram: Contact @kyoceraFS1118MFP
