Two side paper jam
  • nizam
    • Mar 2011
    • 40
    [Jamming] Two side paper jam
    Hi, can any one help me;
    TASkalfa 3500i, The one side copy and print is ok. But the two side copy & print is jam. The jam location is exit job separator is on.
    • 23009
    Re: Two side paper jam
    What jam codes? And if you don't know how to get jam codes, start by buying a manual. =^..^=
    • blaze2000
      • Sep 2010
      • 232
      Yeah man , the jam code will tell lots of information. The best we can probably say is check your sensors in the duplex path.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          There is a QA, the exit unit has been redesigned to correct sticking gates
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • dickierock
            • 252
            Hey,got this before,our suppliers chief engineer told us to take out the exit section,there is a plate behind the solenoid.Loosen the two screws on the plate a half turn to prevent the gate from sticking when it heats up.Worked a treat for us so far.
            • nizam
              • Mar 2011
              • 40
              the frist time 2 side jam code 4218. also jam in one side jam code 4211.
              • texchar555
                Senior Production Tech
                • Mar 2007
                • 142
                hey thats great that they are going to modify the exit unit. My only concern is that everyone seems to think its sticking because of the plate behind the solenoid. This is what ive come across
                The exit frame is warping because of the the old fuser unit. If you shave the collar on the plastic shaft of the guide down this will get you by until your replacement unit comes in.
                • nizam
                  • Mar 2011
                  • 40
                  The Kyocera TASkalfa 3500i the machine company replacement it
                  Thanks and Best Regards, to all
                  Nizam
