KM 3505 Scanner not working anymore....
  • willies
    • Jul 2025
    Hi all, it's great to find this forum, I can tell you!
    I did some work for a client in the last week which involved putting in a new server, switches, remote access etc, and aside from the usual techie hiccups it went pretty smoothly, until the last minute when the client informed me the scanner wasn't working on the printer.
    Some info;
    The old server used to be on 192.168.16.2 address, and the printer/scanner on something like 192.168.16.20.
    The new server is 192.168.1.77 and the printer is on 198.168.1.89, and the scanner on 192.168.1.82 - because this machine has two NICs.
    I installed the FileUtility on the new server (windows 2008 R2 Server, with Windows Firewall disabled), where the share had been created to receive scans.
    I created the 'pointer' to the folder, and clicked on 'start'.
    On the printer/scanner interface, this is where it gets a bit weird. I have put in the IP address of the new server which has the FileUtility software on it in the Address book, given it a name etc. However when you go to the 'Scan' function (one of the four buttons on the right hand side), set your document up (that is to be scanned), selected 'Address book' form the destination area (nothing comes up in the destination list by default), select the new server, press 'Add to recipients', and it gives a little 'x' next to it. You then return to the main scanning interafce screen, click on 'Send to PC', and it take a few seconds, then fails.
    Upon inspecting the Fileutility software running on the Server, when you click on 'Details' (if I remember correctly), it shows no scanner is communicating with the software.
    I RTFM but it wasn't a lot of help to be honest. Is the File utility software meant to automatically direct traffic from the scanner to the folders set in it? How do you get it to pick up/allocate the scanner?
    The printer works fine from PCs on the network.
    The Printer Web interface is accessable with no problems.
    The Scanner Web interface is accessable with no problems.
    Cheers all, appreciate any help on this!
    Will
  • willies
    Re: KM 3505 Scanner not working anymore....
    This might be a stupid question - but do you have to install TWAIN drivers of some kind for the scanner to save documents into a shared folder on a server/pc?
    I thought TWAIN was for directly connected/controlling PC's, locally connected etc...?
      • 23006
      Perchance, could you be talking about a FalconII (KM-3035)?
      The bad news is that the ScanFile Utility does not work well with Server 2008, or Win7. The good news is that if the NS30 firmware is current, you should be able to scan to SMB, or email. =^..^=
      • willies
        Hi
        Yeah I do mean the 3035 sorry.....I was typing the post from another site and hence the mistake.
        "Doesn't work well with Windows 2008".......that's bad news
        However, I did try using the FileUtility software on the old server (which is operating on a new IP address too, as well as the scanner), and that can't receive scans either.
        I think I'm missing one vital link there somewhere
        - Share a folder on the new server (Permissions;'Everyone')
        - Install Fileutility software on server
        - Choose share for receiving scans using FileUtility
        - Change both IP addresses on the KM3035 to the new 192.168.1.X range
        - Edit Address book on scanner to change it to the new IP address of the new server
        I did all this the day before yesterday now so I've slept and may have missed out something else I'd done, but can you see if I'm missing anything?
        Thanks so much for your help.
        • A\ztech
          • Feb 2011
          • 57
          Check the firewall settings to allow scan file utilities
          • willies
            Hi, yeah I completely switched off the server firewall in case it was that, for internal and external networks. And the copier/scanner is on the same switch so there's no hardware firewall in the way....
            • copymech
              • Sep 2011
              • 196
              Ive had problems with sharing in 2008, here is a how to link, mybe it will be helpful.
              Configuring Windows Server 2008 File Sharing - Techotopia
              • rashid120
                • Jun 2010
                • 76
                Some info;
                Will
                check out this file.may be it will help you.revise the settings.
                Thanks and Regards
                Rashid Iqbal
