Any real differences between Kyocera and Copystar?
  • kingpd@businessprints.net
    • 921
    I was kind of wondering if there were any differences between Kyocera and Copystar. From what I could tell, Copystar distributes their lower end machines through "distributors" like Collins, Carolina wholesale, and Nuworld, etc.
    I've also heard people joke that if someone couldn't afford a Kyocera then they should get a Copystar...I always thought they were the same thing.
    How about as far as the individual companies go? Any differences there?
  • Jules Winfield
    • Jul 2009
    • 821
    Re: Any real differences between Kyocera and Copystar?
    Copystars are just rebranded Kyoceras. The only physical difference is maybe the toner cartridges are keyed a little differently, contents are the same, though.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • 23010
      The newer Copystars and Kyoceras use the same exact toner cartridges, unlike the FalconII, FalconIII.
      I wonder if the chipped units are identifiable as Kyocera or Copystar or Utax? I discovered the hard way the Konica Minolta and Oce' units have different chips. =^..^=
      • Jules Winfield
        • Jul 2009
        • 821
        I wonder if the chipped units are identifiable as Kyocera or Copystar or Utax? =^..^=
        Changing the Product Code (U265) could be a workaround for that, provided the cartridges are keyed the same.
        • JR2ALTA
          • Feb 2010
          • 2033
          Copystar is a good brand for a small company.
          From what I understand you don't have the quota like Kyocera.
          Stay away from color though, customers never satisfied and a PM damn near costs as much as the machine.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            There is one more letter in copystar
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • 921
              I too found out that the NEC use different things than the konica minolta...a lot is the same but some things are different.
