Checksum Error F010 on Taskalfa 181/221
  • habik
    • 2013
    Hi did FW upgrade and print board is giving me this msg when printer button is pressed. Copy and Scan functions are OK.
    Cheers for any fast feedback, I am with clients machine on site --stress ...
    What is the best way to upgrade FW on Print board as the CF card with Printer FW does not get recognized by the Machine and my next question is can I slot it in the Print Board CF slot to do the FW upgrade that way? Cheers
    Firmwares HERE
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Checksum Error F010 on Taskalfa 181/221
    I would suspect your firmware is corrupt or the wrong model. Should always work from flashcard.Have you used that flashcard before successfully?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • habik
      • 2013
      Firmwares HERE
      • Venom
        • Nov 2009
        • 765
        Glad you figured it out, I write text files in my firmware folders as a reminder of how to do each firmware...flashcard, USB or IB ver...what slot it goes in.....which firmware gets installed first...The older technology is a PITA to figure out
        • RomanPL
          • Aug 2013
          • 5
          Hi Guys,
          This is an old topic but today I have encountered this problem.
          Does anyone have a printer firmware for TaskAlfa 181 yet?
          Best regards,
          Roman.
            • 8195
            Originally posted by RomanPL
            Hi Guys,
            Best regards,
            Roman.
