KM-3050 - Duplex Scanner Problem.
  • aborad
    • Aug 2011
    • 61
    Printer Model is KM-3050
    My problem is that while I am Scanning Duplex its Scan fine in First page but in Second Page there is a Cyan background.
    sample as attached.
  • Zackuth
    • Aug 2009
    • 448
    Re: KM-3050 - Duplex Scanner Problem.
    Is the DP single or dual scan? If it is dual scan, you might have to clean the cis glass.
    If at first you don't succeed, redefine success
      • 23009
      Start by powering Off, then securing the lower DP cable for the second side CIS. It's really common to have that connector loose, or slammed into a wall damaging the connector, or just connecting poorly. It could be a bad CIS, but check the cables and connectors first. =^..^=
      • aborad
        • Aug 2011
        • 61
        Thanks for your reply.. will check and update you..
