TaskAlfa 500ci. error F040
  • rashid120
    • Jun 2010
    • 76
    TaskAlfa 500ci error is F040.already replaced engine PCB,mian PCB,HDD and Dimm.not able to upgrade the firmware.
    any idea?
  • ss12
    • Jul 2008
    • 289
    Can you not do a forced firmware upgrade using a cf card and the switch under the ops panel.I'm sure there is a procedure in the manual for this
    • taskalfaman
      • Nov 2009
      • 137
      Re: TaskAlfa 500ci. error F040
      hi,
      does the error code appear as a CF code in the middle of the display.
      or on the lower right side, because these are 2 complete different code.
      BR
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • kkendric
          • 301
          CF040
          CF040
          Engine PWB communication error
          Defective main PWB -> Replace the main PWB and check for correct operation.
          Defective engine PWB -> Replace the engine PWB and check for correct Operation
          • rashid120
            • Jun 2010
            • 76
            did same procedure according to the Manual
            right this is communication error
            first we replaced engine pcb
            then main pcb
            then dimm and HDD
            this error is showing after welcome Screen(when loading the HDD) exactly after 2 minutes and when uploading the firmware it gives error (hi voltage cpu error)this error is appearing in the middle. CF card also same(no change).not able to update.
            Thanks and Regards
            • DWise
              • 895
              Are you getting the error after power-cycling printer with communication cable (network, parallel, usb) unplugged from machine? If the error is coming up and you have the communication cable plugged in, be sure and check your Print Queue and delete any jobs that may be stuck, then re-try it.
              Do for one what you wished you could do for everyone. - Andy Stanley
              • habik
                • 2013
                then main pcb
                then dimm and HDD
                Thanks and Regards
                Take the HDD out reformat it and slap it back with NEW FW on USB stick OR CF in CF slot and try to reload the FW TO NEW HDD..
                COMM ERROR between Operational panel and main PCB?
                If changing the dimm on panel make sure you change panel pcb too .
                Firmwares HERE
                • NeoMatrix
                  Senior Tech.
                  • 3514
                  Re: Firmware.
                  Reformat a 1-2Gb USB stick to FAT16. Reinstall the Firmware one single update at a time on the USB/CF stick. Do your "Panel software" , then "Engine Software" etc., etc..... The reason being: you may have some sort of on board memory limitation due to an i/o error. Loading one firmware modual update at a time can help over come this.
                  Wait for each update to complete......... it may take some time to update. Try... to... be... patient....
                  • rashid120
                    • Jun 2010
                    • 76
                    Dear All copytechnet Friends......
                    I will share my Knowledge Regarding this problem.
                    This was a communication error between Engine and Main PCB,but we replaced as i mentioned my previous posts that we tried every thing.we made around 6 visits to this machine (3 different service engineers).
                    At last we pull out this machine and given standby machine to the customer.
                    We sent email to kyocera and they reply??????????????????????? .they faced this problem in field and after changing fuser unit problem was solved.
                    you will be shocked that this was a fuser problem.after changing fuser unit machine working perfectly alright.
                    do you imagine that this was a fuser problem???????
                    please keep updating
                    Thanks and Regards
                    Rashid Iqbal
                    • habik
                      • 2013
                      Thanks and Regards
                      Rashid Iqbal
                      Nice one Rashid Thanks for update Who woukld have guessed that fusers have CPU
                      Firmwares HERE
                      • lebo
                        • Aug 2012
                        • 88
                        F040 on TaskAlfa 250ci
                        Great thanks to you rashid120, you saved lot of time for me.
                        *The same problem F040 on TaskAlfa 250ci - fuser unit error
                        • rashid120
                          • Jun 2010
                          • 76
                          Re: F040 on TaskAlfa 250ci
                          you are welcome my friend....please keep updating if you find some problem that not showing in the service manual....some times it happens...right?
                          Thanks and Regards
                          Rashid Iqbal
                          • kkendric
                            • 301
                            You may need to separate the High voltage CPU firmware for the model you sre having trouble updating from the standard firmware and update it first. I believe that BkackCat had some information regarding this problem. According to him KDA no longer offers this file. I was able to separate these files from the standard firmware file and it does work if you have the correct chosen the correct files
                            • yalex
                              • Nov 2009
                              • 10
                              Hi guys,
                              Can somebody explain me how to separate files for FW update?
                              We're experiencing a CF040 on a Task420i and brains are burning
                              We tried to reset panel, update firmware (USB or CF -> same result).
                              Every time we try, there's a different error (Panel/CPU/Browser....etc) and the mainframe still does'nt work...
                              Thanks for your help to come (and sorry for my french-glish....!)
