TaskAlfa 500ci. error F040
  • KYO_OEM
    • Aug 2011
    • 721
    #16
    • KYO_OEM
      • Aug 2011
      • 721
      #17
      Re: TaskAlfa 500ci. error F040
      Originally posted by yalex
      Hi guys,
      Can somebody explain me how to separate files for FW update?
      We're experiencing a CF040 on a Task420i and brains are burning
      We tried to reset panel, update firmware (USB or CF -> same result).
      Every time we try, there's a different error (Panel/CPU/Browser....etc) and the mainframe still does'nt work...
      Thanks for your help to come (and sorry for my french-glish....!)
      • yalex
        • Nov 2009
        • 10
        #18
        Thank you very much KYO_OEM.
        I tried but either the CF or USB still not work
        Still in CF040
        I've another 420i in our office. What do you think I could replace without risk???
        I'd like to try with the Main Board DIMM
        Is it for you a good idea?
        thanks
        • KYO_OEM
          • Aug 2011
          • 721
          #19
          • yalex
            • Nov 2009
            • 10
            #20
            hi...again.
            I'm sorry, I was not clear enough in my explainations:
            the CF040 appears on a 420i.
            I've another 420i in the office where I can take different parts.
            For the FW update, i tried both CF and USB in an other material and they work perfectly.
            In this 420i, the Firmware update begins and is abnormaly short.
            The result is Panel update error, or Browser error, or High Voltage CPU error...etc ans it's not always the same error.
            I had a call of our Kyocera Support Specialist and he told me to take parts on the other 420i, except the main Dimm (where is stored the serial number).
            I just take my screwdriver and I'll tell you back the results....$
            thanks a lot.
            • yalex
              • Nov 2009
              • 10
              #21
              Dear all,
              I'm so sorry!
              One of my famous (!!!!) team member played with this 420i a few weeks ago...
              He took the RAM for a 300i (the same 2GB) but his problem was due to the Main Controller Dimm (on the 300i).
              The thing is that he put the defective Dimm of the 300i on MY 420i....
              I'm really sorry for the desagrement of my posts!
              Thanks a lot for your answers.
              Kind regards,
              Alex
              • To@ster
                #22
                save setting machine on usb key, then perform u21, re-install setting machine ok
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  #23
                  heyo,
                  have the same problem, 300ci, tried changing fuser first -nope
                  changed engine/main pwb -nope
                  psu pwb -nope
                  the actual high voltage control (lil one) -nope
                  firmware -nope
                  its still dead... ;_;
                  Idling colour developers are not healthy developers.
                  • D Colour
                    • Oct 2008
                    • 216
                    #24
                    Originally posted by rashid120
                    Dear All copytechnet Friends......
                    I will share my Knowledge Regarding this problem.
                    This was a communication error between Engine and Main PCB,but we replaced as i mentioned my previous posts that we tried every thing.we made around 6 visits to this machine (3 different service engineers).
                    At last we pull out this machine and given standby machine to the customer.
                    We sent email to kyocera and they reply??????????????????????? .they faced this problem in field and after changing fuser unit problem was solved.
                    you will be shocked that this was a fuser problem.after changing fuser unit machine working perfectly alright.
                    do you imagine that this was a fuser problem???????
                    please keep updating
                    Thanks and Regards
                    Rashid Iqbal
                    Just had the F040 problem on an old 250Ci - came for a nosey here just in case there was a solution. Fuser unit on the machine was wrecked - replaced and away it went. Thanks Rashid.
                    Everything that has a beginning, has an end.....
