Blank prints and copies TA 300ci
  • Sudsybrew
    • Oct 2011
    • 34
    Had TONS of issues with this machine. Latest required replacing the engine board. After replacement and firmware upgrade, all copies and prints are completely blank. Ay ideas would be most appreciated.
    I would rather be riding, talking to God than sitting in church thinking about riding.
    In wine there is wisdom, in beer there is strength, in water there is bacteria.
  • copymech
    • Sep 2011
    • 196
    Re: Blank prints and copies TA 300ci
    It is really easy to pinch wires on those models. Id start by carefully inspecting the areas where pcbs were removed and reinstalled.
    • Eric1968
      • 2458
      The service manual gives as on of the possibilities a defective engine board. Since you replaced this board chances are that you introduced the blank pages yourself. Like copymech mentioned, check all connectors and look for damaged wiring.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
          • 23009
          The last time I replaced an engine PWB I accidentally unplugged the RFID PWB, and none of the OEM cartridges were recognized. And it was very easy to do. The connectors were really tight, and while tugging on the PWB end, I had partially undone the end at the union connector through the frame.
          This was particularly hard to diagnose, since the manual mentions almost nothing about the RFID PWB.
          Either something didn't get re-connected, or your engine PWB is bad. =^..^=
