usb firmware
+ More Options
Posts
  • spacedust
    spamanamamammmmm
    • 47
    usb firmware
    Hi
    can anyone advised the ideal size of usb pen drive for firmware updates on task alphas and alphards please ?
  • habik
    • 2013
    Re: usb firmware
    Originally posted by spacedust
    Hi
    I use always 2gb... as I use it on Konica Minoltas too
    Fat32 formatted
    Firmwares HERE
      • 23010
      Re: usb firmware
      The files come in just under 500MB, but as a trend firmware files grow over time. That is to say, I expect that the cumulative files will pass 500MB in the next generation. =^..^=
      • aodtech
        • 194
        Re: usb firmware
        I use an 8GB attached to my keys. This way you have enough space to store all of the firmware files on there in separate folders of course. 8GB will work on a Falcon 3 and 2560/3060 and definitely on the newer ones. 16GB is another story. It will update firmware on 500ci and above, but try to do it on the Falcon 3 and 2560/3060... DENIED. So to answer your question, 8GB and under is ideal for any copier that updates firmware via USB.
        • RRodgers
          • Jun 2009
          • 1947
          Re: usb firmware
          Most of the Konica's I work on max out around 2 gig. Anything higher than that it won't see it. Some of the older boxes I work on will only see a 1 gig.
            Re: usb firmware
            Our Kyocera tech representative suggested one memory stick per machine, how do you get several on the same stick?
            Do I just extract (for example) TASKalfa3050_3550_4550_5550ci_v.03.00.0060_(2012-02-06).zip to a memory stick?
              • 23010
              Re: usb firmware
              You have to do some file manipulation. The only file(s) that the machine can read will be on the root. All other files have to be in folders. This could make sense if you have a dozen models of machines, or your laptop was on and running all the time, but I have hundreds of models and my laptop spends the majority of the day shut down in the car.
              Personally I agree with your rep. It's cumbersome, but I have 50+ CF cards and USB sticks, one machine per card/stick. And I don't have to fire up the laptop to rearrange files every time I load firmware.
              • CompyTech
                Super Tech
                • Feb 2011
                • 706
                Re: usb firmware
                I used 2GB. Konica Minoltas I've used 4GB. Have had no probs. Just use name brand memory. I like PNY and Kingston and Sandisk.
