Splash/Welcome Screen
  • monstott2010
    • Aug 2025
    How do you change the welcome/splash screen to use another image such as a company logo? I know it is possible, don't remember how to do it....
  • Eric1968
    • 2458
    Re: Splash/Welcome Screen
    Copy the files to an USB-stick and load the files to the machine using U224. The files are :
    callwin_ext_image.png 180x200pix max 1Mb
    callwin_ext_mes_detail.txt
    callwin_ext_mes_top.txt
    opening_ext_image.png 800x400pix max 1Mb
    I did this only one time during the TA250ci, and I could not find additional info. If you have the SM, U224 tells you how to do it.
      • 23009
      Use an application like Irfanview to format your image to 800x400 pixels, .png file format, and named exactly as Eric specified. Use simulation U224 to import the image. I think there's a bulletin somewhere ... =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Or you can just RTFM.
          • 23009
          I don't think this item ever made it into a manual. =^..^=
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            Is the trademarked? Cuz I'm totally using this for end users I know have the operation guide who call me for simple silly questions...
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • eddie110171
              • May 2012
              • 133
              Image must be 800x480 for the newer models (I think 800x400 was recommended for the Taskafa's) but I use the 800x480 on the Taskalfa's and the newer units and it work just fine. Image must be saved on base directory of a usb drive saved under OPENING_EXT_IMAGE.PNG it must be a saved as a .PNG file or it will not load. I use paint.net its free and easy to use. Install opening image from U224.
              • HaroldMenza
                • Apr 2015
                • 12
                Hi,
                I am new to this whole copy world. I purchased a second hand Taskalfa 250ci which still has the splash screen from the former company. I would like to change that, but I do not know what you mean by U224. I copy my files to a usb device and then?
                Thank you!
                • Tonerkiller
                  • Oct 2012
                  • 668
                  Putting it back to default is very easy. Just go to maint. mode and uninstall it
                  U224 Panel sheet extension
                  Description
                  Changes the image data and the message of the opening screen at the machine startup and the image data
                  and the message of the service call screen to user specified data.
                  Purpose
                  Set according to the preference of the user.
                  Setting
                  1. Write the image data or the message data to the USB memory.
                  2. Insert USB memory in USB memory slot of the machine.
                  3. Turn the main power switch on.
                  4. Enter the maintenance item.
                  5. Press the start key.
                  6. Select the [Install] or [UnInstall].
                  7. Select the item.
                  8. Press the start key. Installation or uninstallation is started.
                  9. When normally completed, [COMPLETE] is displayed.
                  Completion
                  Press the stop key. The screen for selecting a maintenance item No. is displayed.
                  Maintenance
                  item No. Description
                  Display Description
                  Unlock Release the lock of the operation from the system menu
                  Partial Lock Partially lock the operation from the system menu
                  Lock Entirely lock the operation from the system menu
                  Display Description
                  Install Installs the image data or the message data
                  UnInstall Restores the original image data or message data
                  Display Description
                  Opening Img Startup screen
                  Call Img Service call image
                  Call Msg Top Service call screen 1
                  Call Msg Detail Service call screen 2
                  • Tonerkiller
                    • Oct 2012
                    • 668
                    We do not need any of this nonsense.
                    • darry1322
                      • Oct 2010
                      • 817
                      That's Paul from 3 years ago.
                      • narnol02
                        • Oct 2013
                        • 11
                        • ntbann
                          • Jan 2012
                          • 628
                          Sharps can be done.
