km 3050
  • CrapAimer
    • 296
    km 3050
    Hi looking for some advice dont do Kyochera i am ricoh trained have a customer with a old 3050 eith a bare inch or so of the dev roller when taken out and turned manually the toner does coat it but the minute you try and copy the bare part comes back. Any ideas would be a great help
    Many THanks
  • marc
    • Feb 2010
    • 56
    Re: km 3050
    Originally posted by CrapAimer
    Hi looking for some advice dont do Kyochera i am ricoh trained have a customer with a old 3050 eith a bare inch or so of the dev roller when taken out and turned manually the toner does coat it but the minute you try and copy the bare part comes back. Any ideas would be a great helpMany THanks
    You need new developer unit
      • 22936
      Re: km 3050
      This is a monocomponent machine, and you can remove the doctor blade to clean any foreign matter from the developing unit. That may solve your problem. It may require the developing unit, but it costs you only labor to clean. =^..^=
