DF-790 parts enquiry
  • tcs04
    FORMER Techie
    • 1183
    I'm having trouble finding a part!
    Taskalfa5500i... DF-790... Plastic paper guide marked "D6" snapped by customer.
    Sits almost vertically, about 4" deep, pivots from the upper edge, sprung.
    It's the smaller of and highest up of 2 guide plates.
    I've looked at the manual 3 times and seached on line... STILL can't find it!
    Any help appreciated.
    • 22942
    Re: DF-790 parts enquiry
    Is this what you want?:
    • tcs04
      FORMER Techie
      • 1183
      I think so... THANKS!! (Great manuals!!??)
      • xeroid
        Document Technologies Pro
        • 148
        You can get the parts list but it aint in there last time I looked
        303NB24070 Drum Guide is the D6 paper guide
        303NB34050 Label D6 is the label
        • tcs04
          FORMER Techie
          • 1183
          Thanks Xeroid / blackcat / taskalfaman.
          Your numbers match, so I'll order the parts... One final question, is there a clip to hold the guide in? I'm not that familiar with this unit and the peg at the front of the guide is missing.
          Thanks to all again.
          • TripleM160
            Where were you able to find those part numbers? I have checked all the manuals and then searched that part number after the fact and still didn't see them.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              It is in a bulletin, the front pin breaks so they have redesigned with thicker plastic. I've had 3 broken so far.
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • Venom
                • Nov 2009
                • 765
                All that holds it in is a white plastic C clip.
                • habik
                  • 2013
                  Yes, there is a spring at the back that makes the guide to flip to 2 positions - closer to the drum and further apart. A bit ass to get it right.
                  On the front is white plastic C - clip it should be still attached to the mainframe of the finisher, although it depends where it broke.
                  I think I was one of the first one to have it broken, man that was a hunt and a half to get the part. Now is available so you should be OK with the numbers above.
                  Good luck.
                  Firmwares HERE
                  • tcs04
                    FORMER Techie
                    • 1183
                    UPDATE
                    The parts were correct.
                    The guide is modified with the handle at the front rotated about 30 degrees clockwise and the arrow on the label pionts in a different direction to match. Otherwise fits as before.
                    Thanks to all who helped.
