Latest firmware for Taskalfa 4550ci
  • mascara
    • Aug 2011
    • 22
    Please tell me what latest number firmware for TA4550ci and how many tech bulletens for this machine//Thank you
  • Eric1968
    • 2458
    Re: Latest firmware for Taskalfa 4550ci
    Latest version is 03.00.0070. How many tech bulletins? Well there are a lot, but you won't use all of them.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      The released Version here is 3.06
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • mascara
        • Aug 2011
        • 22
        I have installed today TA4550. The machine manufactured feb 2012 with firmware 03.00.0077. Is it latest fw? I installed the machine according to Service manual but This machine had insufficient density of the solid fill. This is especially noticeable in the blue. Paper Weight 80 g\m. I did drum and developer refresh. Are there any ways to increase the density of the solid fills, for example as a Xerox Docucolor240, Canon Irc3200?? I would be grateful for any help, as well as for their help with the latest firmware and bulletins for this machine.
        • Eric1968
          • 2458
          Did you do all adjustments in the Service Mode?
          U469, U464, U412, U410.
          • mascara
            • Aug 2011
            • 22
            I have do U464 and U469 from adjustment\maintence, then U410 from service mode... Tomorrow i will try U412бб, If this does not work try to re-install all
            • Eric1968
              • 2458
              Just a thougth : Use a fresh pack of quality paper. Maybe there's too much moisture in the paper or the paper quality is bad.
              • KYO_OEM
                • Aug 2011
                • 714
                Please try U161/ GRAIN MODE / MODE 1 and execute the U410 again.
                Be carefull, with U161 Mode1 or 2 the paperweight for plain paper will be switched to normal 1 automaticlly.
                Systemmenue/ common settings / Original_Paper setting/ Mediatype settings / Plain paper must be set to Normal 2 back.
                Please try...
