CS3500i copy quality only in black
  • copymech
    • Sep 2011
    • 196
    [CQ] CS3500i copy quality only in black
    I have swapped the drum, developer,transfer door. Half tones and normal text dont not show defect only solid blacks. I have attached samples. Only 6k copy count.
    Sent from my Dell Streak using Forum Runner, Copymech
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: CS3500i copy quality only in black
    If you print a solid page of black and crash the machine before the paper hits the drum are you getting a solid image on the drum?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Looks like laser to me. What firmware you running?
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • copymech
        • Sep 2011
        • 196
        Firmware ver 3.07, I was able to fix this problem by replacing the HV pcb. We initialy thought the laser was bad, but by removing the HV out puts to the developer I was able to get a solid sky shot with out defect. This eliminated the laser in my mind. So I borrowed a HV PCB from another copier and problem solved. Thanks for the responses. Over and out.
          • 23007
          Excuse me for pointing out the obvious, but the CS-3500i can only print in black. It's a monochrome copier. Black and white.
          If the machine you have can print in color it might be a CS-3050ci or a CS-3550ci. And that will make a big difference in the diagnosis. So is it a CS-3500i, CS-3050ci, CS-3550ci, or something else?
