km c 2525e c7101
  • kyogenius
    • Jul 2012
    • 136
    [Error Code] km c 2525e c7101
    anyone got an idea of hw to solve this error code on 2525e ,gears are fine ,genuine toner, connectors on black dev unit are ok,besides changing the k dev unit wat else can be done to clear or reset the error, possible cause ?
    failure is not an option !
  • taskalfa
    • Jun 2011
    • 97
    Re: km c 2525e c7101
    Did you check u155 toner sensor
      • 23010
      The black developing unit is the most likely cause. The rear developing unit bearings will leak, and you'll see a nice pile of developer in the rear body of the machine. If this was a KM-C4035E, you would probably also have to change the black developer drive clutch, and check the shaft and bushings that it rides on. But the KM-C2525E, KM-C3225E, and KM-C3232E all use a developing drive motor, which won't be damaged by the additional load of trying to turn a seizing developing unit. =^..^=
      • kyogenius
        • Jul 2012
        • 136
        thanks, will try to run sim 155 and check the toner sensors, hope it will give me an answer
