Km c2525e poor color quality
  • kyogenius
    • Jul 2012
    • 136
    HI my machine c2525e is producing poor quality copies, i dd grayscale adjustments, color registrations ,dev refresh but still its not producing the colors clearly,could it be my transfer belt ,transfer roller or settings that i need to do. please help
    failure is not an option !
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Km c2525e poor color quality
    Did you run U89 samples to see if only one color is bad?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • kyogenius
      • Jul 2012
      • 136
      will try that sim 89 ,will update you thanks again
        • 23008
        Yeah. Lets see scans of those U089 gray test patterns. =^..^=
        • kyogenius
          • Jul 2012
          • 136
          sure did the sim 89 seems all colors are not bad , but visually my transfer belt looks like its not good my client said they cleaned it with engine cleaner or methlated spirits ,yaah so i wanna try change it, could i be right
            • 23008
            "Engine Cleaner"? I wonder what that could be? I hate to think what it could do to a coated rubber belt.
            You should advise them that it could cost them extra (often a lot extra) if they continue to help you. =^..^=
            • kyogenius
              • Jul 2012
              • 136
              thanks guys i replaced transfer belb its fine now
              • kingpd@businessprints.net
                • 921
                Make sure you bill them for it if it wasn't damaged prior to their "cleaning"
