Re: Km c2525e poor color quality
Make sure you bill them for it if it wasn't damaged prior to their "cleaning"
thanks guys i replaced transfer belb its fine nowLeave a comment:
"Engine Cleaner"? I wonder what that could be? I hate to think what it could do to a coated rubber belt.
You should advise them that it could cost them extra (often a lot extra) if they continue to help you. =^..^=Leave a comment:
sure did the sim 89 seems all colors are not bad , but visually my transfer belt looks like its not good my client said they cleaned it with engine cleaner or methlated spirits ,yaah so i wanna try change it, could i be rightLeave a comment:
will try that sim 89 ,will update you thanks againLeave a comment:
Did you run U89 samples to see if only one color is bad?Leave a comment:
HI my machine c2525e is producing poor quality copies, i dd grayscale adjustments, color registrations ,dev refresh but still its not producing the colors clearly,could it be my transfer belt ,transfer roller or settings that i need to do. please helpTags: None
