kyocera 1635 lead edge 2 inch too light
  • vj200729
    print mate
    • 81
    [CQ] kyocera 1635 lead edge 2 inch too light
    in one kyocera 1635 lead edge 2 inch is too light.i have replaced drum unit,dev unit,transfer assemply,high voltage board etc .but not any change.pls sugesst any solution
  • Mikey
    • Sep 2009
    • 54
    Re: kyocera 1635 lead edge 2 inch too light
    Have you tried to do the test print? Is the problem coming from the scanner or the printer engine? If the problem comes from the printer engine do clean the laser mirrors and glasses. Also try to copy on A3 size paper to see the 2-inch light repeats several times along the path.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • vj200729
        print mate
        • 81
        same on printing and copiying
        • vj200729
          print mate
          • 81
          in a3 also only top edge one inch light
            • 23009
            ... and does that light area repeat on the A3 page more than once? If yes, what interval? =^..^=
            • vj200729
              print mate
              • 81
              no, in a3 also only top edge is light for 2 inch
              • Mikey
                • Sep 2009
                • 54
                So you're saying that both copying and printing have the same result. And on A3 size paper only the leading edge is light and exactly the same result with A4 size paper.
                This information tells us that there is no problem with the scanning and laser unit as well as the optics. You can then imagine that the lead edge of the paper tends to move away from the transfer charger or the drum unit. You have problem with the mechanisms involving the stability of the paper along the path near the drum and the transfer. Try to scrutinize the mechanism.
                Another thing is to check the calibration of the transfer voltage. I hope this helps.
