BLANK COPY ON KM 2550
  • kyogenius
    • Jul 2012
    • 136
    [Misc] BLANK COPY ON KM 2550
    HI
    i got km 2550 thats producing blank copies, tried the High voltage pcb on another machine its fine, could it be my drum unit or main pcb or engine board, the machine is behaving normally, warming up and responding normally,no error code
    help pliz
    failure is not an option !
  • JustManuals
    • Jan 2006
    • 9838
    Re: BLANK COPY ON KM 2550
    Paul@justmanuals.com
      • 23010
      Will it print any internal report or print? With what results? =^..^=
      • kyogenius
        • Jul 2012
        • 136
        its not printing anything even the sim list or from computer, just blanks
          • 23010
          There are a couple of possibilities. First lets rule a few things out.
          You have primary charge. The absence of primary charge is black copies.
          You may have a transfer problem.
          You may have a developing problem.
          You may have a laser problem.
          You can further rule out transfer. To do so make a skyshot, then emergency stop the machine while the paper is next to the drum. Is there a developed image on the drum? If yes it's a transfer problem. If no, it must be either developing or laser. =^..^=
          • kyogenius
            • Jul 2012
            • 136
            will try this tmrrw ,thanks once again will update you on any new developments
            • kyogenius
              • Jul 2012
              • 136
              thanks BLACKCATT i suspect my prob might be on dev unit though its turning,will try another unit, when i remove my main charge corona unit i am not getting a solid black copy, only one side on edge is a bit shaded, meaning when i do a copy i get a slight image on the edge, thats how far i have gone with this machine so far
                • 23010
                I think you're on the right track. =^..^=
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  Did you stop copy half way to see if image is on drum? Most common issue is the transfer roller springs missing.
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                    • 23010
                    venom: I think he did. So far, everything is pointing toward some sort of developing problem. =^..^=
