Re: Task Alfa 300i
I'll keep that in mind. Thanks.
Task Alfa 300i
Re: Task Alfa 300i
Some of the other Kyocera fusers have separate parts available, but not this one. About a year into production a bulletin came out stating that the fuser was only going to be offered as an assembly. Really, it's a very simple fuser along the same lines as the FalconI, FalconII, and FalconIII. The rollers are not the same size as any of the others, and the assembly cost is quite cheap. Hardly worth attempting to rebuild. I do hold onto any fusers that reach the 300K maintenance intact. I use them to cover the situations where they don't reach the 300K.Leave a comment:
Re: Task Alfa 300i
The CS-2560 or KM-2560 is identical. Others, not so much. =^..^=Leave a comment:
Task Alfa 300i
Hi, I was wandering if there was any other machine that has a similar fuser unit to the task alfa 300i. I mean any of the old KM machines.Tags: None
