Color Bands on a Kyocera FS-C2126MFP
  • alpha-omega tech
    • 80
    [CQ] Color Bands on a Kyocera FS-C2126MFP
    I checked the bias connections. Replace the HV unit. Downloaded the latest firmware. The PDF is a sample of an internal Status Page. Has anyone ran across this issue before.
    • 22997
    Re: Color Bands on a Kyocera FS-C2126MFP
    It looks to me like poor black drum cleaning. Maybe black drum ground? No I don't have any of this series. =^..^=
    • alpha-omega tech
      • 80
      There where two pins in the drum unit connector touching. This is weird because the copier was working fine according to the customer and all of a sudden it started copying and printing color bands in color mode and black bands in b/w mode. I separated the pins touching in the connector on the black drum and all is good. It is the connector on the left/bottom when putting the drum in copier.
      • madas
        • Aug 2008
        • 313
        Thanks for the update
        madas
