KM-C3225,specs in solid areas
  • Copydoc Ric
    • Jul 2025
    I've come accross a problem on a KM-C3225 copier. When printing to the copier,envelopes, the heavy black letterhead like return address has spects or lite dots in bold print. When I make copies of a test chart onto a envelope the blacks are solid. I should also mention that the envelopes are printed in the full color mode, and the test samples were in black only. Thanks for help, Ric
    • 30253
    bypass
    is the bypass media set for envelopes?and if you are running color thats about .10 for each envelopes printed
    not very cost effective
    • Copydoc Ric
      Reply Customer color printing on envelopes
      Yes the customer is printing in color on envelopes.
        • 23008
        I'm not terribly surprised. Have you ever had a double feed and the image appeared to have poor transfer? That's because additional transfer is required for thicker (read: double layers) of paper.
        With envelopes there are areas with 2, 3, and sometimes 4 layers of paper. How do you compensate with transfer voltage when the thickness of the paper varies?
