Kyocera Mita KM-8030 feeder designation
  • CaptnRed
    • Apr 2011
    • 57
    Hi Folks, Got a KM-8030 in need of a major PM. Got all the kits and part numbers for the main body, but not sure what the feeder's model number is.
    What is the designation for the feeder?
    If you anyone has the list of all the accessories designations for the 8030 that would be helpful as well.
    Much thanks,
    Anthony
    • 23008
    Re: Kyocera Mita KM-8030 feeder designation
    The document processor is standard equipment on the KM-6030, KM-8030, so does not have it's own model designation. But if you're wondering about standard maintenance parts you can start with:
    1 3H607020 Pickup Roller
    1 3H607010 Feed Belt
    1 3H607120 Separation Roller
    1 3H607120 Separation Torque Limiter
    These are the possible accessories:
    Possible Accessories: Document Processor (standard), PF-650 Large Capacity Tray (4000 sheets letter only), PF-660 Large Capacity Tray (4000 sheets Ledger), DF-650 3000 Sheet Document Finisher, BF-1A Booklet Folder (requires DF-650), MT-1A Mailbox (requires DF-650), PH-4A Punch Unit, Print System (V), Scan System (G), Data Security Kit (B), IB-22 Wireless Network Card, HD10 20GB Hard Drive, Printer Memory Upgrade DIMM 32K/64K/128K/256K (SD-100-512A: Harrier memory).
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • CaptnRed
        • Apr 2011
        • 57
        Much Appreciated Blackcat4866! Saved me a headache, I'm not familiar with Kyocera-Mita yet. This model seems to be a nice work horse.
        Anthony
          • 23008
          True that. =^..^=
          • habik
            • 2013
            I'd like to add every 700k to change duplex roller and keep duplex pulley lubed and smooth. Keep stock of Feed Switch A's and you'll be fine. Also lube the fuser motor gears. Clean filters on each visit. Happy days.
            Firmwares HERE
            • CaptnRed
              • Apr 2011
              • 57
              Habik there is only happy days if you share your case of Heineken!
              Thanks for your input, will be sure to add the duplex roller, feed switches and fuser gears to the PM.
              Cheers!
              Anthony
                • 23008
                post #10 of this one:
                http://www.copytechnet.com/forums/ky...4200-code.html
